Trw forged pistons is there a light Piston pin available?
Call up Trend and order whatever you want. You will be drilling the crank if you use the same % during balancing
10 years ago I bought a set of Sealed Power forgings for my 3.8 and it came with the 'light pins'.
Earl brown speed pro doesn't sell the pins separate.
The Pistons I have don't have the coating on the side like yours.
Do you have a suggestion before I pull the trigger on the je pins?
My pistons are the same as yours. No coating on the skirts. The only other pins I found that would fit are Trend pins that full throttle carries.
Do your slugs have the pins with the small ID like on gnttype.org? I've never seen those in real life. Every set of TRW/FM/Speed Pro slugs I've seen have the pins like on my picture.
