TRW piston Pins
BadAssGN
Certifiable Member
I have a set of TRW (sealed power forged ) pistons and 3 of the Pins are damaged, These are not available seperatly
I am hoping someone here has broken or scored a TRW/sealed power piston and have some pins laying around, The hyper pins are the same.
Thanks in advance to anyone who can help.
pins
You can buy the light weight J&E pins but you will have to balance the rotating assembly.
Maybe, contact Weber Racing Equipment
http://www.4wre.com/
I have those Speedpro/TRW pistons in my engine. Weber installed them using lighter Ohio Piston & Pin pins (also rebalanced). I would assume they have some of the Speedpro pins laying around if they do the replacement often.
