Try Guessin My Hp
marred4life
Banned
ok can some guess my HP on my regal, here are some numbers from the track today,
best run 7.854 at 89.62 in the 1/8
and here are the mods
T70 LIMIT TURBO
UNMOLESTED STOCK BLOCK AND HEADS
FULL BOLT ONs, ( FM, TURBO, HEADERS, 55LBS, FUEL SYSTEM, ETC.....
380O STALL NON LOCK UP, BUILT TRANNY
SO CAN ANYONE HELP ME OUT, I HAVE NO IDEAL WHAT MY HP COULD BE.
380hp@3500lbs. You should be able to get a lot more out of it if you turn the boost up to 30psi or more. Make sure you have the fuel available to do so. The stock heads and cam are chocking the hell out of your combo though.
i have the same exact combo, except for dfi gen 6, & i had the boost branked up lightly to 25psi..i shouldve went to 30psi...
what was your mph in the 1/4???? mine was 116
