SignUp Now!Hello,
Does anyone know what the typical combustion chamber volume is on Turbo Trans Am cylinder heads?
Also, are the exhaust port gaskets the same between the Turbo Trans Am and Grand National cylinder heads?
Thank you for any help,
Paul Lohr
Here is some technical info on the TTA that should answer your questions. Also, the exhaust port gaskets are unique to the TTA as the heads are. I just rebuilt one and these are the only gaskets that I could find for them, but work perfectly. Hope the info helps.
Remflex RF13-012 header gaskets
http://www.turbotransam.com/forums/showthread.php?t=4956&page=4
Pontiac contracted the TTA engine with Jeff Beitzel and his PAS Engineering in Van Nuys, California, and the work took place in its 40,000-square-foot City of Industry facility. Once completed, the engines were shipped back to GM, installed in the cars, and then returned to PAS for a brief period of testing and quality-control checks before they were offered to the public for sale. Jeff Beitzel, who was the president of PAS, had his personal 20th Anniversary TTA (one of the 1,555) sent to ASC and made into a convertible. Today it's rumored to be owned by a private collector. Only 1,554, were built, Pontiac created the F-body supercar based upon the GNX engine program. Initially, Pontiac engineers wanted to use an all-aluminum Chevy or Olds 307 V-8 powerplant in the TTA. That plan never came to fruition, so the RPO LC2 3.8L Intercooled Buick Turbo V-6 engine was chosen. The 1989 Turbo Trans Am's utilized a 3.800 in. x 3.400 bore, Buick 231ci/ 3.8L "25526109" engine block, w/ "SG1" cast into the side. A nodular-iron crank, with 4 cross-drilled main bearings, fillet mains and rod journals, plus 6 counterweights PN: 25511229. A set of cast Armasteel 151mm-long cast rods, and special design hypereutectic pistons designed to work at 46.4mm of total compression height to produce a compression ratio of 8.0:1. It was fitted with cylinder heads from the existing traverse V-6 3800 Series I heads, PN: 25536702, which yielded superior combustion chamber design & exhaust flow of the GN/GNX design. It allowed room for the downpipe to fit, and also gave more clearance around the strut towers & A/C box on the firewall. It used a hydraulic roller camshaft, with 192/196-degrees duration at .050, .409/.434 lift, 1.71 intake valves and 1.49-inch exhaust valves, with special 1.65:1 rockers. A crank trigger ignition was used to fire the spark plugs more effectively. The spark plug wires of the TTA are unique, embossed with the 20th Anniversary logo, they have plug shields on their ends to prevent burning. A specialized Garrett T-3 turbocharger w/ a ceramic-impeller, provided a maximum of 16.5 psi boost, fed through a GNX-based 12-fin intercooler to a "CERMATEL" (Ceramic/Aluminum) coated pipe to a 75.5mm MAF, 58mm throttle body, and then forced into an aluminum intake manifold. 91 or greater Octane was mandatory to feed the beast's thrist and protect against detonation. Inside the fuel tank, a baffle surrounds the fuel pump and ensured a steady supply of fuel to the pump during sharp turns, specifically designed for the IMSA (International Motor Sports Association) "Showroom Stock" competition. A high volume electric fuel pump was used to feed fuel to a high-pressure Bosch 237 fuel pressure regulator, and metered out to 6 Bosch 28 lb/hr injectors. A specially recalibrated ECM and custom PROM operated the computer system and maintained the balance effectively. Although there are substantial differences between a stock Turbo TA chip and a stock Grand National chip, the ECMs are identical. The spent gasses were expelled via TTA-specific Stainless steel 3-into-1 headers, down into a high flow catalytic converter, and passed though a 2.5-inch exhaust system with a crossflow muffler, and out through dual, polished stainless steel "splitter" tailpipe extensions, similar in style to those used on the Trans Ams of the late 70's. The engine was seriously underrated at 250 hp. In actuality, the TTA motor reportedly made 301 hp on the PAS engine dyno and 10 to 15 lb-ft higher torque than the advertised 340 lb-ft. Chassis-dyno test results of bone stock cars, yield numbers that correspond with TTAs typically making around 220 HP to the rear wheels. A mid-year change was made to the Turbo TA's plastic turbo inlet tube, and replaced with a durable unit with a clamping rib on either end to keep the hoses attached more securely. (A note to assist in saving your stock one from collapse: cut a short 1" length of 3" dia exhaust pipe and insert it into the end of the inlet tube. It's a perfect fit and will allow tighter clamping forces to be applied) The engine also utilized a horizontally-mounted A/C PF-1218 oil filter with an anti-drainback valve to prevent oil starvation at engine startup. The original TTA's serpentine belt was slightly longer than optimal and was a common malady on stock trim car as the belt stretched with use, heat, and age. All Turbo T/A's came equipped with a highly-modified 200R4, 4 speed Automatic-overdrive transmission an custom lockup torque converter, all specially calibrated with performance-optimized shift points, and strengthened internals. This power was then transfered via a RPO JG1 aluminum driveshaft, with hardened Spicer u-joints and a Spicer yoke, out to a 9-bolt 3.27 limited-slip Borg-Warner rear axle. The entire combination was capable of quarter times in the mid 13's in bone stock trim.
Here is a link to the full article.... sorry about the misinformation. I thought everything posted on the internet had to be true....LOL
I thought it had a lot of great info and was a very interesting read. You can tell the author is enamored with the TTA as we all are, it is great that we have had so much good communication with Scott Kelly and Bill Owen, and Jan and others to investigate to put a real history to our cars, and very grateful for it... I know I am.
http://www.necamaro-firebird.org/forums/viewtopic.php?f=39&t=5459
SG-1 block is not a cross drilled 4 boltmain block, TTA came with flat tappet cam, TTA did not have a ceramic turbo cahrger impeller, TTA intercooler is different from GNX it has 2 or 3 less rows of fins I know because Richard Clark and I have compared the two before. TTA heads will not flow more than the stock GN heads we have flowed both at Richaed Clarks and the GN heads would low slightly more.
Michael
