Been doing some reading and with the A/F ratio being much lower than gasoline, will I be needing to completely change all of the values on the PE/AE tables to fully utilize the benefits of E85? Not to mention change the overall A/F ratio for all conditions? I want to start with a 50/50 mix and then move up to a 25/75 mix, which is what I've read to fully optimize the benefits of E-85. I'll be running the car in all climates and when I add ALKY, there will be no reason to go any higher.
Have you guys been able to get by, by just adding fuel and timing as needed for your mixture, with the tables already loaded onto a chip like Eric's?
About all I have the ability to tinker with currently are the user adj. features on my TT chip.
Will something a little more sophisticated than Powerlogger and a wideband O2 be needed for logging data?
I was going to post the data I logged and the changes I've made, but my comp. froze, and don't want to do all that again.
Been running a 25% mix of E85 and premium with nothing but positives to report. Car was running a bit rich before and I've only had to up the fuel slightly.
So far here's what I've noticed: smoother idle, better off idle response, NO KNOCK up to 20 psi on 20 Degrees of timing, a lower tone to the exhaust at cruise, noticeably quicker spool-up. In general the car "feels" like it just got a tune-up. And I'd imagine that the Ethanol helped to clean out the fuel system as well.
Milage is down only slightly, I'd guess say 30 mpg down to 27-28. Not sure if I can expect worse with a higher percentage, but then again, I am sure the car is not perfectly tuned, as its still a work in progress, but the results I've observed so far speak for themselves. Never have I been able to run 20 psi out of this car with this chip with anything but either race gas or at least 20% toluene. O2's look good, and the injectors still have some room left to go. And never has the car "felt" so good for normal driving.
Before I up the percentage, what fuel filter do I need to change to?
