Car started running lean the other day, can't seem to figure out what's going on.Run a pt-51 , v-2 front mount, 50 # inj., rjc plate, 340 walbro, exhaust and ans boost controller. Was running 20 lb.boost on 93 octane mils in the 812 range. Now I am getting knock 4-5 deg. at 17- 18 boost. Changed heated o-2 to reg. o-2 sensor with new sensor because of several passes a few months ago with leaded race fuel. Running 42-43 lb fuel pressure also. Adding fuel doesn't help either. Changed gas stations numerous times. Can't get consistent milivolt readings either. They range from the low 700's to 870's. The car used to get a degree or two of knock when you first mated it and then went away .Now i am getting way rich early on 880-900 no knock, then leaning out on top end 760-810 4-5 deg knock. Also have a modified bosh reg. that according to my guage moves around 2 lbs. now.Could this cheap o-2 sensor be causing this, fuel reg.,chip, computer or what. Please HELP!
