The PTE has you plug the normal oil supply for the turbo that comes from the block; where the oil pressure sender is located.
PTE remote filter has a seperate line that supplies oil to the turbo off the oil return side of the remote filter adapter.
You could rig up a seperate oil line off the Summit remote filter and plug the normal oil supply from the block, then it would be similar to PTE.
Gary
