Turbonetics cheetah stage 1 turbo
JohnE87
Looking for some info on this turbo. I have done several searches and haven't been able to turn up much information. Would like to know what it is capable of. E/t goals currently are to break in the mid 11s. Will be ordering alky control, 60# injectors, and TT chip.
I would call Jack or Brian at Cottons Performance. They are a Turbonetics dealer.
http://cottonsperformance.com/
I'm sure others will chime in as it was a fairly popular turbo back in the day.
I remember guys running it, but that's all I know.
Basically a 5957e cast compressor wheel equivalent to a te-60 in flow 57-60lb/min, needs a 2800 stall to work good, should get you into the mid 11s but the boost needs to be pushed over 25psi if you have un-ported stock heads.
