turn signal flasher
abrasv
Just switched front and rear lights over to led. I need a new flasher for the turn signals. Does anyone have the part number from either O'reilly's, AutoZone, or Napa? LED taillights look awesome but won't work without changing that flasher.
NAPA shows this one by Grote.
I haven’t used this one, but one similar. I ended up using the load resistors on my ‘94 Cutlass Convertible due to the key in the ignition chime going off after a few minutes of driving with the parking/ headlights on.
On that car I ran the load resistors on the front turn signals only, the rears were ok.
Just a heads up to check all functions with the LED flasher installed before you drive too far.
Appreciate the answer GX1. I ended up on line at Amazon and after doing some research bought one from a company called MEMOTRONICS out of Texas. Comes with a ground wire. Part # EF32RLNP. Works great.
