Twilight Sentinal
buickturbo-t
Before I start let me say that I did use the search engine and did not come up with a similar problems.
The twilight sentinal will come on every once in awhile when the ignition switch is just turned on, but only stays on for about 20-30 seconds and then will shut off. This is usually in the garage and I have even put a cover over the sensor to see if it will continue to work and it wont. What could the problem be? I always leave the switch on but it never seems to work when driving at night. Any ideas would be great, because I think that it has the potential to work.
Thanks Adam
