Twin stock GN turbos, How Fast???
rking
Senior Member
I am just throwing around some ideas and I was wondering how fast someone can go on a twin turbo setup using two stock GN turbos. I think I once heard high 9s, not for sure though. Oh yeah, the rest of engine would be fully ported, polished, FAST system for tuning, FM, and of course enough fuel. So how fast do you think?? TIA
well, unless you are using a Stage block, you won't be running 9's very often with those twin turbos.....in which case it would be cheaper to build a single turbo Stage block that will go much faster!
Tony De Quick was working on a kit to do exactly what you want.
You certainly need a Stage 2 block for this kind of project. You are stepping into the HIGH dollar projects when you decide to run twin turbos and go mid to low 9's
good luck
Yeah, I know that 9s cant be run on a stock block. I was just trying to figure out what kind of times two stock turbos will support. Would they flow enough to run high 9s. I know it would cost alot, I was just wondering how fast they could possibly go. TIA
they can go that fast.......check the archives....CAS ran some tests...sadly, I think the stock block tests all blew up?
