Types of knock
V6POWER
Senior Member
I know that knock caused by too much boost for the octane being used is bad. Is knock caused by DP hitting, loose motor mounts, transitional, etc. just as bad?
All knock is bad...
False knock is bad in terms of not running up to optimal performance when that occurs. It's pulling timing out when it shouldn't be. Lost timing is lost performance. If you have the stock wastegate system you are also loosing boost when this happens.
I feel transitional knock can be damaging over time. I don't like to see it at all. If it's there there is more tuning and/or chip program changes to do.
You want to tune out all knock retard and be able to just tickle the sensor (1-2 degrees) when you are on the edge. That will give you best performance and longest engine life. I personally like to see zero knock counts and zero retard through the run with max of 2 degrees or less retard.
Thanks Chad. I also tune for zero knock at the track but I do get transitional knock on the street when I kick it down from a roll and I wonder if it is because of the timing in my Extender chip. I have 23/21 and maybe the 23 is too much. Any thoughts on that? I see we have about the same combo except for the turbo. Do you still run the stock D5?
Originally posted by Mr URL
All knock is bad...
We have transistional detonation, and tip-in preignition.
Like you said any detonation is bad.
And
Any preigintion is bad.
Trouble is tip-in preignition sometimes silent, and you and the acoustic knock sensors don't hear it, so we're back to reading plugs again.
Between the Burst Knock Retard, and WOT low RPM timing table there really shouldn't be a problem with the transistional stuff.
All it takes is the right chip........
Transitional Knock
I've read numerous posts about transitional knock becoming more pronounced when running a higher avg. boost following an
ETOH-injection system.
Basic questions:
1.) Is this TK more due to the injection, the higher boost, both?
2.) Who burns good chips taking into account the added variables within an ETOH-injection system?
Your thoughts on this are very much appreciated!
