SignUp Now!look under your seat,and remove the watch..just kidding..maybe a audable knock sensor?foregn2 said:When i'm at WOT above 85mph I hear a ticking noise from the passenger side of the car. Could there be something wrong with my turbo. This happens on the freeway when i'm on it for a bit. Help, thanks
sounds like detonation,you need better gas,less boost,or alky..foregn2 said:hahahahah tommy
yeah sounds like a little pinging/ticking type noise
o-crap,if your not familier be carefull..its when your engine pings because your octane level is not high enough for your compression in the motor..you need to get a scanmaster and i knock sensor,if you hear it you are killing your motor..usually it is on top end,but can happen anytime..for now lower the boost..get alky injection,which will keep you octane levels hi during acceleration,best thing you can get..go in the alky section and talk to razor/julio..he will guide you..call him,he owns alkycontroll...im not too smart on these,yet,but i know your killing your motor..hows your oil pressure?it beats on the bearings..foregn2 said:I'm new and not real engine savvy but what is detonation?
you do run pump gas..then when you get into the boost it injects alcohol like a nitrous jet would do..you put about 1 gallon in a tank that looks like your overflow tank,and when you get low a light kicks on..it last a while(depending on how much you race)...its a must,but yes you can lower the boost..last week i had it at 30psi with 93 octane(no pinging)..look at my post in the alcohol section..get a aftermarket boost gauge and a knock sensor that lights up when its detonating..heres a pic of my motor and the overflow tank is my alcohol containment and its injected into the up pipe...foregn2 said:ok, i know theres a adjustable wastegate, istn that how to adjust the boost. The previous owner told me it was set at 18lbs, but how he knew i dont know bcuz the stock gauge is till there, no aftermarket gauges.
Right it only happens on top end runs. I dont want to go alky, i run 93 pump gas. So i guess i need to adjust boost and i should be ok?
my best advice to you ,if you really dont know how to check oil pressure,and you dont know what detonation is..is to stop driving your car and start reading or become friends with a mechanic,that knows these cars...good luckforegn2 said:how do i check oil pressure.
i live not too far from the owner of alky control/julio,so i brought it to him..it took him like 3 hours,but he is a pro..so maybe like 6,if you take your time..i too had alot of knock,so i put cam-2 gas in and it helped me get to like 22 psi,but i wasted my 02 sensor..with pump gas i only got to like 17-19 without knock..after he put it on we got to 26psi and i left it till last week when it went to 30foregn2 said:Tommy nice looking engine. Mine is just as nice with alot of chrome underneath. Is that Alky hard to install? and how much that cost?
foregn2 said:Quick 6 KC
uh i dont know what detonation is bcuz i dont really get into the technical stuff of cars. But since this my first really muscle type car instead of luxury car i'm trying to learn
Everyone else:
Thanks for your help and replies. I will take all advice and try to fix problem.
