I hope someone can explain this for me. Here are some of my observations and thoughts and want to know if anything needs to be corrected in my mind. I started having a problem with my stock T starting to knock at about 65 mph and continue to get worse if I were to stay in it (I had always been able to run up to 18lbs or so with my 18 degree JC street chip with 0 knock). I noticed that my formerly perfect MAF sensor was now only maxxing out at about 225-227 when it had always gotten to 254-255 with no problems before. I got an MAF translator and a 3" sensor and now it is running perfect again. So......my thoughts are this: the computer was reading the maf sensor lower than the actual amount of air flowing in and therefore not enriching the mixture as much as it actually needed, thus creating the lean condition and detonation. However, I am not sure the computer actually does this type of adjusting and I would have thought that the O2 sensor would have told the computer to raise enrichment. Perhaps the differential between the MAF reading and reality was too great to overcome? If anyone that can explain this all to me understands my question, I'd appreciate a response
