i went to the track last night and to my suprise i could only pull 13.5# thats it. i opend up the boost controll all the way, and eventually ended up pulling the hose off the wastegate, but no luck.
I'm thinking its likely a vaccume leak somewhere. are there any common places where i should start looking? for this leak?
Also i got a code 32, thats some egr valve code, i haven't checked to see exactly what it means, but could that be leaking my other 6 1/2# of boost?
I know i made one mistake, when i was hooking up my tcc switch i put it in the lower row 2nd hole from the left. (first with a contact thing) and turned it on. when i did that it almost killed the engine and i figured somethign happend and it was trying to lock in first, which i thought was impossible. so i turned the switch on (grounded that plug) shifting into 2nd. I have no idea what that did, or if it would have hurt anything. stupid operator error...
