Vacuum Brake Question
rbarragan
73
4
8
35
I have completed a vacuum brake conversion on my 87 T. I am now experiencing a soft pedal when and the pedal stays on the floor for a bit.
1. I tied in the to the PVC vacuum line.
2. I have tried to bleed brakes 3 times and have seen no air and no change in pedal feel.
3. The master cylinder was brand new and the booster was out of a junk yard.
4. Is the front bowl of the MC reservoir for the rear brakes?
I have completed a search of the forum and I am suspecting it’s the booster but wanted to get some feedback from the forum.
Turbo6inKY
Short Guy
Jun 18, 2001
1,468
333
83
41
Louisville, KY
blog.andrewdscott.com
Does the pedal harden if you pump it a few times with the engine off?
If not, you still have air in there, possibly in the master itself. I'd pull the master back off and bench bleed it again to make double sure it doesn't have air in it. Then reinstall and bleed it again.
When you bleed the front calipers, you may need to unbolt them from the spindle so you can hang them with the bleeder absolutely upright.
  • Like
Reactions: 1986 Buick GX1
Top Bottom
