When replacing these, are there any specific torque specs? Also is draining the oil necessary? This is a pretty straight forward job right. Nothing really complicated or any special tools needed are there?
There has been a lot of discussion on this topic, do a search and you will find a new Fel Pro gasket part number that has a metal insert. Can get them at Pep Boys for about $30 (they are reuseable)
Jeff
i use cork valve cover gaskets from autozone they are the same as felpro in a different box called engine seal 2.99 they seal really good no leak you have to use some stuff called indian head gasket sealer with them not rtv
