Valve Springs
GOT JCE
RIP Ruka Jean
If your valve springs need replacing should you to take the heads off to do them or do it right on the motor?Roughly how much should the labor cost.Thanks,AJ
All you need to do is take the valve covers off and have the right tools.
The #6 cylinder could present a problem for some shops without a spring compressor tool like Kirban came up with, most likely they could find a way to do that one however, I'd ask the shop first to avoid any problems.
A pro should be able to do them in 2 hours, 2.5 tops.
Including installing the new felpro viton valve seals, and new rocker shaft buttons, and new cover gaskets, and cleaning the pushrods.
Parts are another cost item for the things listed above that could/should be done during the job.
I have some new springs sets and kirbans tool to do them yourself if interested pm me.
