Video of timing accuracy
22lbChevelle
786
3
18
WA
I think original credit for the trigger wheel swap goes to the late Bruce. There are a few old threads that describe how to install them and use them with the stock ecm to achieve a fast start up. I am only utilizing the 18 tooth wheel with my megasquirt ecm. I don't have the fast start with this setup but I do get accurate and stable timing.
norbs
doing more with less
May 25, 2001
5,983
60
48
50
canada
Can you tell us what car the 18x trigger wheel set up comes off and the correct part number for the type II module also.
thanks
norb
Daniel Jost
Squirtin six
Oct 11, 2003
1,226
35
48
30
Peoria, Illinois
www.msextra.com
thanks
norb
Norb, I think he is running coil per plug ignition or something of the sort with his megasquirt powering it as he posted above.
22#, it would have been great if you took a video of set timing @10° while revving the engine with both trigger wheels as you would really see different timing error since there is such big gap in teeth on the 3x wheel you would see a lot more timing error than the high tooth count.
,Dan
Reggie West
TurboBuick.Com Supporter!
May 28, 2001
2,065
223
63
50
Temecula, CA
Would love to see more info on this. Someone should come up with a 53 tooth wheel like on the LS motors.
kidglok
Balls Deep
Oct 10, 2010
2,241
223
63
32
Union County, NJ
I think this can work with bob baileys tr6, just need the supporting software and the trigger wheels
karolko
1,085
29
48
Alberta, Canada
subscribed.
I would like to know how something like this could be used on the FAST XFI system as well. If MS3 can do it, I assume XFI is capable of it as well.
Adrian
Daniel Jost
Squirtin six
Oct 11, 2003
1,226
35
48
30
Peoria, Illinois
www.msextra.com
How would we be able to assure that the timing will be set at a set timing to check the stock ECM? If a custom chip was burned with a flat timing table we could get a good comparison. I have access to a stock ECM/IGN turbo buick but at idle the timing will naturally move around especially if the engine is revved since it is using the stock timing tables. With the Megasquirt and I am sure most aftermarket ECM's you can set the timing static for checking base timing. Also in the MS3 you can set spark latency which will help out with "Spark travel" on low count wheels.
,Dan
