wlaukaitis
3rd Member
- Aug 5, 2003
Hi Folks,
OK, I just the car back together after a few gasket replacements (upper plenum, valve covers, throttle body, vacuum block) and a new Cat. I also remove the trans inspection cover to have a gander at my trans/oil waterfall leaks. I noticed a heat shield that was rubbing some wires, I think it was the starter wires so I bent it out of the way a bit.
I have a somewhat flickering Volts light. Initially it would be off at idle and get brighter as the RPM's increased. I shut it down for about 2 hours and went back out to start it. Still off at idle but as the rpm's increased it would flicker.
I could not get a good reading from - to alt +, I have to clean a good ground and Alt +.
Battery voltage is 11.6 even with the car running, as RPM increases I could hit about 12.5 (maybe at 2500 or so)
I'm thinking Alternator, I guess it decided to crap out on me. I saw a post where you take a VOM and go from Batt + to Alt + (the terminal) is this true?
