C
coach
Guest
Ok Guys,
If you have watched my build thread or a few other posts, you may know I've hinted about this.
I have another 8.5 housing that is getting narrowed and I am welding the Ford ends on the tubes to get rid of the C-clips.
My question is... with a 1/2 to 3/4 inch deep frame notch and perfect placement of my 15x10 Vectors, can I get the 325's in there...without any issues driving it? I dont want to be hitting potholes and rubbing up top everytime it happens. I run airbags and only use them when I have the trunk loaded up and traveling.
If any of you are running the 325's, let me know what you did and how they fit. I think since I am narrowing my housing and can place my tires exactly where I want, I may be able to do this. Its more of the up and down travel I am worried about. They are 1 inch wider then the 295's and there are guys running those without any notch. I am going to notch another frame and reinforce it correctly, so I'm not worried about a notched frame on a daily driver.
Lets hear some feedback or thoughts on this.
Thanks as always
Coach
Thanks as always
Coach
