Mar 26, 2004 #1 K klcsmooth Member Joined Jan 9, 2004 Messages 70 I just got a new wastegate selinoid and one of my wires is cut on the plug the wire to the computer is still good. Where does the other wire go to?
Mar 27, 2004 #2 T Taffy Member Joined May 25, 2001 Messages 1,168 There is a pair of wires that goes to the solenoid. The colors should match up. If your wires are cut and you can not see the wires, you need to go to www.gnttype.org and check out the wiring diagrams to see what wires you need.
