- May 24, 2004
Finally got my t-type up and running again from the motor build but I can't tell what is going on so I have to get this fixed! When you turn the car on the scanmaster will display 2.0 then go to flat bars like usual. When you crank the car it will show the O2 changing up and down like it should BUT when you hit the button to go to the other readings it will just flash one dot real fast in the middle till you turn loose of the button then it will show the O2 again. Will not scroll to the other stuff any ideas please!!!!! Daniel Ray
