What crank to use ? And turbo?
GregGnTn
47
14
8
48
Knoxville
Starting to rebuild my engine what crank to use? Going back stock not sure about eagle cranks seem reasonable priced has anyone used ? And turbo going to use TE-44 what brand and best place to buy, using 60lb injectors. Any help would be appreciated..
dank GN
BlackArts Automotive (661)993-8277
Jan 11, 2009
3,451
401
83
SoCal the high desert
Many people have used the eagle crank. If you have the cash I would go with that crank and get a good machine shop to install 2 billet center caps with arp studs . That should hold you over for awhile with the bottom end .
deezdad
923
211
43
Mendon, Ma
Got a few options on the turbo the one I like is turbonetics air cooled bb version, compliments a small cam / tight converter combo.
earlbrown
runs with scissors
May 26, 2001
7,005
1,234
113
47
lagrange, GA
If you're going stock, a stock crank will be fine.
As far as the turbo, if you're buying new, get something a little newer than a TE44. It's a fine turbo, but there's more efficient units out there at the same price point.
Top Bottom
