What does a Qtrim and a Ptrim wheel measure?
SPEEDSTAR
Any body know what each one measures, just thru the exhaust housing hole , the dia. that you can see , without disassembling the turbo.?:confused:
thanks JEFF
Thanks Russ, mines definetly a p-trim, I know I ordered a p-trim,but I got to lookin at it and it thought maybe its a q trim by mistake cus it looked really big , oh well , p-trim it is !
Nothin wrong with that! The major diameter (the part you can't see) of that wheel is 2.922 and a Q-trim is 3.111
so are all big shaft turbos the same wheel if they are the same trim??
mines p-trim 70-1 so will say the housing off a 63 or 72 be the same long as they are p-trim?
Yup! I had Craig send me a Garrett .63 the other day to replace the 4 bolt housing coming on the other 70 I am getting. A "P" is a "P". The change is in the compressor wheel where you find trouble.
