what does this (underhood) relay control
JonnyBoost
Turbo Junkie
Its the closest to the firewall on the drivers side above the wheel well.
one of the 2 wire harnesses on it was dissconnected so i pulled it off to clean the contacts, but when i had it in my hand i could hear loose parts rattleing in it. so i opened it up and there was tons of rust bouncing around inside it.
is it a fan relay or something? the car runs fine i'd just like to know what ive been messing up running the car w/o it plugged in
thanks,
jon
thanks Claude,
i didnt think gnttype was still up
Coolant Fan Delay Relay... ill have to do a little research
anyone else have a similar experience?
Exact same "sounds" from my relay. Went out and bought new relays....new problem (note my thread on rc fans running).
I hate electrical crap!!!
Best place for that relay is in your sock drawer. :)
Take both connectors off it to be sure there's no current drain to your battery.
Won't hurt anything you can tape them disconnected up if you want to.
