What injectors do I have?
moose102
Moose
Due due to the previous owner of my Buick being untrustworthy, I thought I would ask the trustworthy crowd here. When I purchased this car a previous owner said it had 220 lb injectors in it. I can't seem to find any information on them. They look like Bosch to me, but I couldn't find any information on them.
Thanks, I have done that. They come up as a bosche for a ford 32/lb per hour. Of course there are many different numbers.
Part of the # looks to have been ground off....0250158***.
Could be some "genius" is protecting his "SSS" inj ID.
Those are DW injectors for sure. Not 100 percent sure but I think those are 1200s You can call dw and they will tell you
Since you turned out to be such **** after the deal on the car, it is hard for me to help you, but the Lord says to turn the other cheek.
The injectors are 140# DW's which list at ~$500.
Here ya go, Nick:LOL:
Pick a cheek, and let the OP know which one!
Thanks, your such a nice guy. I figured it out which Im sure I will be doing for a while since you have been so tight lipped except here on TB.
Here is a bunch, not all, of info on what was done to the Limited!
Engine - 4.1 stroker, forged rods, crank, pistons, billet roller cam, TA alum heads, ported, roller rockers, ported intake, SFI balancer & flexplate………………………………….$10.000
Trans - stage II build w/10” converter…………………$3000
Turbo - Borg-Warner 4-bolt……………………………$2450
Custom headers…………….…………………………$1100
Custom downpipe, 3” exhaust…………………………$650
Baer front brakes………………………………………$1400
Custom metal inner fender wells………………………$1000
Custom intercooler/pipes/3”throttle body……………..$1250
New springs front & rear………………………………$450
Rear frame notch/U&L arms, antiroll bar……………..$2100
Aburn posi w/Ford retainers/30 spline axles…………..$2250
Dakota Digital dash……………………………………$1500
Vintage Air conversion………………………………..$4000
Alum radiator w/dual fans…………………………….$650
FAST XFI w/custom wiring harness…………………..$3500
Billet fuel sender, -6/-8 lines…………………………..$1600
