I replaced my PCV Valve today an this was inline above it. I figure is is some type of valve like ATR used to see that prevents boost from entering the crankcase. I took it out but did not put it back in!! From what I can tell shouldn't just a PCV alone keep boost from entering the crankcase. I blew thru the PCV from the small side of it an cannot blow thru it. This valve I took off I cannot blow thru either side. It just has a plunger on one side an I took a pen an pushed o nthe other side an the plunger moves out onthe other side an sucks itself back in! Is this normal?
