What is this?
pacecarta
MAGNA
Staff member
Aug 1, 2003
9,129
783
113
RIP racewaypark, NJ
its for the under dash pullout ash tray lamp , with console they used a light blue 3m schotchlok tap to connect the console shiftindicator lamp grey wire
pacecarta
MAGNA
Staff member
Aug 1, 2003
9,129
783
113
RIP racewaypark, NJ
pullout ash tray was only used on column shift and mounted under the radio ..that lamp socket he showed goes into that ashtray.
your console indicator has a black (ground that clips to shifter base) and that lamp should also have a grey wire (has been known to break at the socket and ground out on shifter and blow the lps fuse) that goes up to the ashtray socket grey wire and connects on with a scotchlok squeeze connector
  • Like
Reactions: grass doctor
grass doctor
1,514
688
113
44
saint augustine fl
pacecarta is like the Cindy Lauper of Buicks ( time after time )
If you're lost you can look and you will find me
Time after time
If you fall, I will catch you, I'll be waiting
Time after time
A TRUE JEDI MASTER
grass doctor
1,514
688
113
44
saint augustine fl
ALL BS ASIDE thx pacecarta for all your knowledge, when all else fails you answer , much respect and greatly appreciate you even if you make me look like a dumb ass ....
salvageV6
Daily Driver
May 25, 2001
15,012
434
83
64
Connecticut
And if you have the twilight sentinel option turned on and the gray wire grounds out and blows the LPS fuse you will most likely blow up the ASIC chip inside the sentinel amplifier box. Don't axe me how I know that.... :rolleyes:
  • Like
Reactions: Jerryl
