screamindemon2
- Sep 14, 2005
I heard to use diesel oil to break in just wondering whats best..30 over TRW,212-212 comp cam,& cat forged crank ,gt6776 turbo ,vig 3500 stall, HOPE IT RUNS SOME GOOD NUMBERS JoJo
machinegun said:I do not recommend break in on synthetic. Only use a good dino oil. The rotella would be a good choice. After the engine is broke in then go to a synthetic. Mobile1 is good although I may try the new penzoil synthetic to see how it works.
231Turbo said:Comp reccomends the cam breakin with Rottella T 15 w 40
VadersV6 said:Do not ever use synthetic for break in! Otherwise, it wont BREAK IN.
Use a non synthetic oil with alot of moly in it. Dont use any oil with the starburst symbol, before or after break in, on any engine with a flat tappet cam. Those are the oils that had the zinc and phosphorous reduced. The quaker state Q oils have alot of moly, but use the regular one, not synthetic Q oils. I ran royal purple for many years and beat the living hell out of those engines, and never saw a shred of damage. The longer you use RP, the better cause it gradually coats everything in moly. But the Q oils, like the semi synthetic Q oils, have more zinc and phosphorous and moly than RP. Thats what Im running now. But dont use it for break in. Use 2 CANS of EOS during break in, with a decent dino oil. After cam break-in, drain it all and throw in 5 more quarts of cheap dino oil, with NO EOS supplement and a new filter. Get out there, warm up the engine, and do some low boost (about 10psi), WOT runs up to 5000rpm. Maybe about 5 passes. After that, drain it, and throw in some Quaker State Q high rpm oil, or your favorite synthetic with another new filter. I personally HATE Mobil 1. Valvoline SYN sythetic is an excellent synthetic, as are all the Q oils, redline and RP. A supplement that is way better than EOS is valvoline SYN oil treatment...they make a SYN oil, and a SYN oil treatment, in case that confused you. But the SYN oil treatment is a full synthetic oil treatment, so dont use it on break in. The main reason you want EOS, is to coat the flat tappet lobes with moly, since the moly assembly lube wipes right off after the engine gets fired up. EOS has lots of moly.
Half a bottle of SYN treatment has enough moly, zinc and phosphorous to protect the lobes with each oil change, although running Q oils by themselves will be fine cause they are really fortified. Hope this wasnt too much info. The break in advise came from what I learned on the dyno and with our race motors. The guys at that place knew their stuff, and after tearing engines down, with flat tappet cams, that came in first place in every race through a whole season, to find every bearing, cam lobe, cylinder wall, piston skirt, all looking brand new..I tended to follow their advise. A HARD break in with clean dino oil, seats all the valves properly and breaks everything else in properly. No glazed cylinder walls, leakdown or blowby. No flat lobes, worn valve guides, scuffed skirts, etc.
Its too late for you now unless you're careful, but one of the best things you can do with a new motor is to spray all the casting flash all over the block and heads with carb cleaner...LOTS of carb cleaner. It gets out so much old dirt, abrasive materials, fine metal particles that hot tanks dont get out that you wouldnt believe it. There is a HUGE amount of crap embedded in that casting flash, and it finds its way into your new bearings, rings and skirts...well....everything. Normal solvents, brake cleaner, soap and water...nothing gets that stuff out like carb cleaner does.
