Well using Cal Hartlines recommendation i am using Autolite racing plugs #AR3932, But i will be running into the 30+ # range when is dialed in.
In Len Freemans 109 block car we used NGK R5724-8
We found that the autolite 103 can run a little hot at high boost and it can melt the plug. But i am sure others have had different results
I believe a R42LTS would be the correct Delco plug,Running in the mid 20#s the 103's should be fine
