What should be done to engine grounds?
BJM
Senior Member
I have looked GNTTYPE and I found a description of what goes where. I can't find any suggestions as to what needs improvement. Where is the main ground strap from the engine to the body of the car or should I add one.
What comes in these aftermarket ground kits?
Unopened unpulled motor I would just inspect them with a mirror on the back of the head and if they look and feel fine I wouldn't touch them.
Ground strap on the gas tank EDGE metal to the frame is a good idea.
Ground strap from the frame to the battery, I have double posts on mine, is also a good idea especially with stereo add ons.
Relocation kits are good if you pull your engine out a lot. :eek:
I think they are a good idea just because they're more accessible, & the grounds on the head seem like they wouldn't be as succeptable to road grease/grime.
Salvage is right though in that they will work fine where they're at as long as they're inspected every once in a while.:)
I just bought a kit from a board member because they aren't pricey & I'll use it on the new motor for the GN I bought.
They will just be easier to check while troubleshooting, ect. :)
