What tire size are you running on your 8.5" Vector rims? (T-Type look-a-likes)
Geoff87
Administrator
Staff member
275/50's? 275/60's? or....?
Any rubbing/clearance issues? :confused:
TIA! ;)
i run 12.5 x 28 mt et streets on 8.5 centerline no rubbing 2 airbags and the lips are not rolled i also use 275 50 bfg dr on this rim with 3.5 bs 275 60 will work also ;)
A little advertising here, but if you guys want to install OEM caps onto these AVR rims my brother has made aluminum adapters that go in from the back that allow you to snap stock OEM caps in place...these adapters are hollow allowing cap removal if required.
Timothy Dirks and I have them...nice...you can find Timothy's response if you search for "Paging Timothy Dirks"....my opnion is ovbviously biased :)
Don't know cost for sure, have pics if interested.
To answer the original question...I will run MT 28 x 11.5 ET Streets.
Regards, Bob
I have been running the BFG Euro 305x50x15 since 1992 on my silver T. I have air bags on both sides and the fenders are rolled tight.
These are the largest that I have seen. Been thinking about trying the 325x50x15 BFG Drag radials on my 10" wide Vectors.
Gary :cool: :cool:
SeePictures
Hey guys I haven't found lugs for these rims yet?? You guys find any that look "stock"?? Where??
Thanks, Bob
I'll do a search for the post, as I do need some center caps. :)
I have two pairs, one for street (275/50's or 275/60's), and one for the track MT ET Drags 26 or 28 X 10 (when my current MT's wear down). :cool:
Anyone run these on the street, on regular radials?
BTW, my rims are of the universal bolt pattern type. Who makes open ended, ET style lug nuts? (GM 3" Metric Studs)
