1987 Grand National for sale 63,000 miles hard top. Engine-nick micale built 231 600 miles 30 over ccp forged pistons, bms steel crank standard not cut, stock resized rods arp bolts used thur out motor bhj balancer.sfi flywheel,steel ported ,polished heads receiver grooved for lock wire gaskets,new freeze plugs line bored toque plated,214/210 atr billet hyd roller,heads totally rebuilt roller springs,new push rods, hardned rocker shafts high flow front timing cover nick modified, also has biggie oil filter adapter light front stock size crank pulley,ported intake to heads,kenne bell 70mm throttle body,helmco 70mm race bonnet,terry Houston down pipe poston headers,two center steel main caps with girdle,not leaking,engine tie down translator plus,with extended harness to run inside car everything mounted in glove box,also adapter harness for timing hook up no cut wires.all motor work done 9-1-03 caspers 4 inch mass air,brand new sears die hard battery 10-1-03 with warranty three inch bowling green custom exhaust,hooker areo chamber mufflers,gtq 71 turbo new 9-1-03 600miles with warrenty,83pph simens injectors new 9-1-03 600 miles modified computer for low imp,injectors,pte front mount 3 inch piping ,with the new brackets to bolt up no cutting up car,double roller timing chain,ram chargers dual fans new 4-1-04,controller,jimm’ys trans vigilante 9/1-2 converter with stage right trans brake trans warrenty,warlbo 340 in tank warlbo external above tank guys give me some times that you think she will run i have an idea but would like to hear some times that will give me goose bumps!!tom p.s will be for sale soon.
