what will she run
supergn6
1987 Grand National 63,000 miles hard top. Engine-nick micale built 231 600 miles 30 over ccp forged pistons, bms steel crank standard not cut, stock resized rods arp bolts used thur out motor bhj balancer.sfi flywheel,steel ported ,polished heads receiver grooved for lock wire gaskets,new freeze plugs line bored toque plated,214/210 atr billet hyd roller,heads totally rebuilt roller springs,new push rods, hardned rocker shafts high flow front timing cover nick modified, also has biggie oil filter adapter light front stock size crank pulley,ported intake to heads,kenne bell 70mm throttle body,helmco 70mm race bonnet,terry Houston down pipe poston headers,two center steel main caps with girdle,not leaking,engine tie down translator plus,with extended harness to run inside car everything mounted in glove box,also adapter harness for timing hook up no cut wires.all motor work done 9-1-03 caspers 4 inch mass air,brand new sears die hard battery 10-1-03 with warranty three inch bowling green custom exhaust,hooker areo chamber mufflers,gtq 71 turbo new 9-1-03 600miles with warrenty,83pph simens injectors new 9-1-03 600 miles modified computer for low imp,injectors,pte front mount 3 inch piping ,with the new brackets to bolt up no cutting up car,double roller timing chain,ram chargers dual fans new 4-1-04,controller,jimm’ys trans vigilante 9/1-2 converter with stage right trans brake trans warrenty,warlbo 340 in tank warlbo external above tank guys give me some times that you think she will run i have an idea but would like to hear some times that will give me goose bumps!!tom p.s will be for sale soon.
__________________
mylast1
I'm not gonna give you any goosebumps......it certainly has potential
but what is your track experience......tuning experience.......suspension.....tires??
just parts doesn't = go fast:D
and if ya don't have a rollbar, I would say 11.0
look closer guys....he's got more things on his car than both of you combined.
i think mid tens would be easily possible.
then again...how would i know...i only run 11.0 on a slow day.
surej
Should be an easy 10.0 car, since that was the question...... I'll leave the judgement calls to those better equipped.
surej
Let me look closer......
Wow..Your Right,He does have more stuff than I do.......
And Without a Rollbar in the car,He isnt going to go any faster than 12.0 without getting booted from the track......
Just like your superfast 11.0 slow day run,Without a Bar...It will net you a spot in the Stands watching for the rest of the day...:p
I Think he Knows what the car is going to run,And I would say Probably low 10's All Day....
But what Do I know,I only have a mid 11'sec Capable TTA...:rolleyes:
hmm...i have never been kicked off the track and no i dont have a cage.
welcome to the real world , not the NHRA run world that the internet makes u think it is. test and tune nights around here are not very strict...sign the waiver and drive.
in other words...a cage doesnt make a fast, it makes it legal.
he asked about the time capabilities of his combo...period.
p.s. you should have said 13.0 unless he has a helmet:rolleyes:
surej
I originally had a couple paragraph Reply about the "Real World".....But I really dont want to be bothered....:rolleyes:
So.....
Supergn6......Good luck with the car..The thing should really fly...;)
Hopefully your part of the vast minority(That Live in the "Real World") that can run whatever times you want and not be booted If you dont have a Rollbar..
On test n tune nights around where I race, they are not very strict. They are strict when it comes to helmets and people riding with you but they let the roll bar and other things slide on non-big events.
