what's all needed to go mafless
I recommend the following:
MAFTPro (of course)
3 bar map sensor
MAT sensor extension
Boost contoller and harness
some kinda pipe to fill the hole where you MAF was :D
Installation is straight forward, just take your time and read the manual! I love it!
Or go with the FAST system (big bucks!)
Here is where I relocated my MAT sensor (Down on the up pipe by the fan)
Vader,
would there be any advantage/not, to having MAT sensing air that is intercooled?
cya
Sorry for the late post but being in Germany now my bed time hours are a little sooner than the States.
Pipe is from http://www.buickgn.com/. Comes with the ends and clamps. I had to extend it as you can see!
The MAT is in the intercooled air, before the alcohol injection.
Yep it is very close but it works, thank goodness!
When I get home in October, those pipes will be welded and polished :biggrin: . Also will be installing the dual fan harness from Caspers or Racetronics. Got all kind of goodies to put on. Now maybe it will look as good as it runs ;) .
