thanks guys...here is the build up on the new motor...let me know if this is enough injector for the 44 i currently have
i will have Ross pistons .030
fererra 6000 series valves
ported heads
intake port matched
comp 212/212 cam
rjc girdle
smc alky
turbotweak chip
Block will be bored and torque plate honed, recondition the con rods, aline hone the mains, cam bearing and freeze plugs installed, Balance the rotating assembly, compition vavle job, deck the block, surface the heads,Turn crank shaft to specs for proper clearances. Thermal cleaning of all parts
ported heads
intake port matched
comp 212/212 cam
rjc girdle
smc alky
turbotweak chip
