HellOnWheels
HellOnWheels
- Feb 3, 2002
I've installed a .63 Garrett turbine housing that's been modified to fit my "P" trim 63 turbo, I've also installed a BtsC electronic boost controller using 2 stock wastegate solenoids. As long as the BstC is turned on I've got a good handle on controlling the boost pressure. However, when I turn the BstC off the boost will go thru the roof!??. The wastegate arm is adjusted out as far as it will go, and the wastegate hole is opened up to 1". I've checked and double checked all the vacuum lines and all are in good condition so they can be eliminated as the cause, am I right in thinking the w/g hole need to be enlarged????
Anyone else have this problem????
TIA,
HOW
TIA,
HOW
