I finally got around to installing the wheel spacers that I referred to in post #8. They will not fit on the front hubs so I had the raised flange machined off so that the hole was 70mm straight through. Even after doing this, I still had to take the Dremel to the hub and do a slight bit of grinding of material off the hub so that the spacer would slide completely onto the hub and sit flush. The aluminum GN rims have recessed spots on the back of the rim which allowed the slight protrusion of the factory wheel studs to go, thereby making it unnecessary to grind the factory studs down. All in all, it wasn't too bad and it pays to be in the Army where a machinist works right across the road from where I work.
The car definitely steers more responsively and doesn't nose dive when taking corners as speed. The left wheel does rub very slightly on the inside wheel well when turned full left but it does not do this when turning full right. Not a big deal though.
