Where does this female plug goes
Buckshot G/N
I was just looking over my car and notice this , with one of the 3 wires broken . Does anyone know were it plugs into, and it's function purpose. Thanks.
Thanks Chuck, So what you're saying is when my mechanic 15 years ago installed a high volume fuel pump with hotwire kit , he unplug it ? And there is no need for it ?
That’s oil pressure switch under turbo. If you have a gauge in the car that is prob we’re the sender is screwed in and reason it’s not going to anything
Fat Nat.. I have the plug. & play GNX S/W dash with oil pressure gauge , Oil pressure is working perfect
Yea see if the sender is in the spot of the factory oil press switch for the light on factory cluster
Take a pic of the brass block screwed into the side of your engine with turbo feed line on it
