I have FAST XFI logging kit and now a GNS cluster. So I need a T fitting to use two oil pressure senders. Anybody know a part number, vendor, etc? thread sizes? Anything helps. Thanks.
Home Depot, hardware store, plumbing supply. It's a common fitting. Take a piece of the tubbing with you and do a match-up for whatever works.
Or if your using AN connections, you can get the coupler fittings from Summit or Jegs with the NPT threaded hole in them for a pressure transducer or gauge.
