1986-87 Common parts for Turbo Regals
GM and Non-GM Parts
DESCRIPTION PART NUMBER NOTE
A/C compressor spacer .030" to align pulleys 14047730 .
AC/Delco Tread Sealer with Teflon 14011040 .
Air Conditioner, delete bracket/pulley (4.3L S-10 pickup) 10118713 .
AC orifice tube assembly GM #3033879
AC Delco #15-5151
AC accumulator GM #2724877
AC Delco # 15-1681 (should be painted black prior to installation)
Belt for use with above - Dayco 5060610 .
Air Dam, Passenger's Side 25525980 .
Air Dam, Driver's Side 25525981 .
Antenna Mast 22038195 .
Applique, shift console Black (GN) 25517561 .
Gray (T) 25528767 .
Belt - serpentine 10105307 (old number 25525518) Kelley-Springfield serpentine belt #635K6
Original Equipment GN/TTA 10105307 (old number 25525518) 21.36mm x 1619.0mm
Factory Replacement TTA 12399983 20.80mm x 1603.0mm
Body Mount Cushions, Lower . .
Position #4 457915 .
Positions #3,5,7 377801 .
GNX (2 per car) 488610 .
Bolt, Rod Cap 25531956 .
Bolt, Main Cap 25517607 .
Bolt, Head -torque to yield Long 25525953 .
Bolt, Head-torque to yield Short 25527831 .
Boost Solenoid 1997157 .
Brace, Alternator accessory 25525338 Discontinued
Brake pressure switch 18018141 .
Brake accumulator 18038507 Old number 18014978
Brake pump & motor 18011279 .
Brake hose, motor to sump 18011403 .
Brake pushrod 18011544 .
Brake Pushrod boot 18011398 .
Brake cover with diaphragm 18M758 Old number 18013293
Brake Power Booster -Vacuum Brakes 1800120 .
Brake Pedal - Vacuum Brakes 1256193 .
Brake - Powermaster rebuild kit 18020067 Has changed to: 18038510 (AC/Delco #18M757)
Brass Brake Combination Valve 25509419 .
Bumper Filler LH Front 12336191 .
Bumper Filler RH Front 12336190 .
Bumper Filler LH Rear 20428396
Bumper Filler RH Rear 20428397
Body Mount Cushions Lower 457915 .
Calpack 16036503 Alternate: 16036504
Cam thrust button w/needle bearings 25532588 .
Cam Sprocket(nylon over teeth) 25523115
Clips, Headliner Trim, Front 20058837
Clips, Headliner Trim, Side .20340201
Clips, Headliner Trim, Rear .20061050
Coil 25533542 .
Coil-to-ignition module screw 25533541 .
Coil-to-ignition module gasket 25526450 .
Coolant Temp Switch(on intake under FPR) .3053190
Coolant recovery reservoir 25525470 .
Crank Shaft, GN/T-Type 12350247 .
Crank Shaft, Turbo Trans-AM (Same as above but has cross drilled main journals) 25535742 .
Crankshaft Balancer Spacer "seal" .030" (max. .060") 25523377 .
Crank Sensor (Complete) 25525667 .
Crank Sensor Bracket 12537113 (AC/Delco #213-280)
Crank Sensor Bolt 12537114 (AC/Delco #213-281)
Crank Sensor 12537109 (AC/Delco #213-292)
1986 ESC Module 16022614 .
1987 ESC Module 16051654 .
Cam Sensor With Drive 25516915 .
Cam Sensor 25518357 .
Cam Sensor Shaft O Ring 1959331 .
Cam Sensor Spacer Shims 1837617 .
Door Striker 20151275 .
EGR filter 10159525 .
EGR Valve 17111570
ECM 1227148 .
Engine, Short Block minus cam 25527476 List $1575 on 6-91 Discontinued
Exhaust Turbo Outlet Pipe (Downpipe) 25526459 .
Exhaust Catalytic Converter 25103338 .
Exhaust "Y" Pipe After Converter 25525383 .
Exhaust Pipe Over Axle LH 25520013 .
Exhaust Pipe Over Axle RH 25520012 .
Exhaust Muffler 25520009 .
Exhaust Tail Pipe LH 25520011 .
Exhaust Tail Pipe RH 25520012 .
Exhaust Manifold LH 25527391 .
Exhaust Manifold RH 25527378 .
Exhaust, Catalytic Converter Hanger 25525381 .
Fan delay relay 25527402 .
Fan Hi and Low Relay 25526984 .
Passenger Side Relay Shroud 25518460 .
Fender well, inner plastic passengers's side (Superceeded PN, original part no longer available) 25526024 .
Flexplate Turbo 81-87 (heavier piston/pins) 25512350 .
Floor mats - black (Regal) Front 22528628/2252629 .
Rear 998842 .
Frame Reinforcement Rods Left 472169 .
Right 472170 .
Front Dash Panel .25520629 (only in blue)
Front Fender LH 25505891 .
Front Fender RH 25505890 .
Fuel pressure regulator, Turbo TA and Somerset 25523720 .
Fuel Rail 25524302 .
Fuel Rail, Feed Line (Pipe Assembly) 25526146 .
Fuel Injector O Ring 10031124 .
Fuel Injector Wire Harness 12060425 .
Fuel Pump Strainer Sock 25055458 .
Fuel Line 'O' Rings Return line at FPR . 22516256
Fuel Line 'O' Rings Feed line at fuel rail 22514722
Fuel Meter Gasket (Between Sender and Tank) 12337247 .
Fuel Pump Relay 10038490 .
Fuel Pump Hanger/Sender 9167390510 .
Gasket Kit, Engine Overhaul (Contains all engine gaskets EXCEPT valve seals) 12328748 .
Gasket Kit, Top End (Includes head gaskets, intake gasket, and valve cover gaskets) 12328759 .
Gasket kit, Front cover (Includes cover gasket, water pump gasket, mechenical fuel pump block off plate gasket. This kit will also fit Buick 3.0L FWD V6) 12337540 .
Gasket, Oil Pan 25521994 .
Gasket, oil pick up screen to block 24501259 .
Gasket, Head gaskets (composite) 25528486 .
Gasket, Head gasket (steel shim) 25524599 .
Gasket, EGR to intake $1.14 25530599 .
Gasket, IAC (round) 25530697 .
Gasket, Upper Plenum to Intake 24502089 .
Gasket, Throttle-Body to Upper Plenum 25517008 .
Gasket, Turbo Inlet bell 25514608 .
Gasket, Vacuum block (top of throttle body) 25536028 .
Gas tank, with TR baffle 22523080 .
Governor (transmission) 8655976 .
Grommet, Pass Side Valve Cover 1264486
Grille Assembly (1987) 25526614
Headlight Bezel LH Chrome 25525091 .
Headlight Bezel RH Chrome 25525090 .
Headlight Bezel LH Black 25525088
Headlight Bezel RH Black 25525089
Heater hoses Inlet 25525213 .
Outlet 25525214 .
To water pump 25525228 .
Water pump Bypass 25525245 .
Hood Insulation Pad 25525977
Idle Air Control (IAC) 25527077
Ignition module 25526449 .
Intake Manifold 25527221 .
Intake, Upper Plenum 25525146 .
Intercooler Air Duct 25526377 .
Intercooler Fan 25526398
Key Lock Cover (Black) 20496885 .
Knock Sensor 10456287
License Plate Frame 14083879 (Flips down & stays)
Lifter Set 5234485-12 .
Low fuel warning assembly 6432974 .
Mass air flow sensor 25007866 Discontinued
MAF Sensor (3"Impalla SS) 25180303 (AC/Delco 1#213-352)
Moldings, Fender well, (Black) .
RH front 25519950 .
LH front 25519951 .
RH rear 24098649 Discontinued
LH rear 20498650 .
Motor Mounts Left 1255273 .
Right 1255274 .
Oil Cooler Adapter 25530885 Discontinued
Oil Cooler Adapter O Ring 25530999 .
Oil Pressure Switch 25036378
Oil Pressure Switch Molded Connector 12085529 (has 3 white wires which need to be spliced in)
Oil Pump, stock 12337732 .
Oxygen Sensor, (Stock) 25162693 (AFS-20)
Oxygen Sensor, (GNX) 25162753 (AFS-22)
Oxygen Sensor, (GM) Heated 25312179 (AFS-74)
Oil Supplement, GM Engine (EOS) 1052367 .
Posi Traction Additive 1052358 .
Posi, Clutch Pack 00231127 .
Positive Battery Cable 12157883 .
PCV valve 25095468 AC# CV893C
PCV grommet 1381487 .
PCV hose 10055808 non turbo part that works-must cut to fit
PCV hose Dayco 87000 3/8" hose with a 90 degree bend that can be trimmed
Pipe - master cylinder to proportioning valve (front) 25519995 .
Power Steering Fluid Reservoir 25531140 .
Power Window Switch- Eschutcheon 20152960 .
Push Rod, Stock 25510025 .
Radiator hose Upper 25525229 .
Lower 25523616 .
Radiator Cap RC27 .
Rear Carrier Pin 26056109
Rear Carrier Pin Bolt 14056196
Rear End Posi Lube(80W-90) 1052271
Rear Lower Control Arms (1LE Camaro ) 10164151 .
Rear Lower Control Arm Bushings (1LE Camaro) 10164152 .
Rear Spoiler Center 25518278 .
Rear Spoiler LH End 25518291 .
Rear Spoiler RH End 25518290 .
Seal, Intake Valve (no seals used on exhaust valves) 25535162 .
Seat Belt guides - F-body enclosed style Right Black 20549668 .
Right Gray 20549798 .
Left Black 20549669 .
Left Gray 20549799 .
Servo Cover (Transmission) 24200798 .
Outer Piston 8678941 .
Inner Piston . .
Shifter Cable 25537476 .
Shifter Applique (Grey) 25528767 .
Shifter Handle (Grey) 22525558 .
Speedometer - 140 mph from Anniversary 84-85 Turbo Riviera (use the faceplate and cluster only) 25076576 .
Starter, Light Weight Unit 10465293 (95+ F-bodies w/v8) AC/Delco # 323-488
Starter, Bolts for Light Weight Unit above 12338064 & 14037733 .
Steering Wheel Cap (Grey) 25531981 .
Steering Whell Cap Allenhead Bolts 25507579 .
Spring, Hood (AC/Delco # 325-271)
3rd Generation Camaro 36mm Lightweight Hollow front sway bar 14094344 .
Bushings for above 14094389 .
Switch, Hobbs GM 25503871 .
Throttle Position Sensor (TPS) 25036663
Timing Chain Tensioner 25532546
Timing Chain Tensioner Spring 1358909
Transmission Dipstick grommet 1259475 .
Transmission Valve Body Separator Plate 8657309 .
T-Top molding strip - RH
20066040 .
T-Top molding strip - LH 20066041 .
T-Top weatherstrip - RH 20211820 .
T-Top weatherstrip - LH 20211821 .
T-Top door weatherstrip - RH 20201220 .
T-Top door weatherstrip - LH 20201221 .
These five numbres are the inside and outside window felts/weatherstrips. Fasten to the tops of the doors
20674282 r.h. side
20363106 r.h. side
20674283 l.h. side
20363107 l.h. side
00327006 cut to fit at the bottom of each door .
T-Top Center "T" (This is the part that the t-tops fit into) 20674345 .
Tail Light Mounting Gasket 5967657
Top Engine Clean 1#1050002 .
Throttle Valve Cable 25532115 .
Torque Converter Clutch Solenoid 8639900 .
Turbo Inlet Gasket - Rivera 1261269 .
Turbo oil drain gasket 25537227 .
Turbo to downpipe seal 1262500 .
Turbo center housing rotating assembly 25527601 .
Vacuum Block Assembly (TTA) 25536304
Vacuum Check Valve (one way) 14047619 .
Vacuum Check Valve HVAC/Cruise 14056648
Valve, Check 25525315 .
Valve Stem Umbrella Seal Kit 12511890 .
Valve Springs, LT1 ~105# Seat Pressure 3927142 .
Valve Cover Grommet (passenger side) 1264486 .
Wastegate - adjustable 25527603 .
Wastegate control hose assembly 25525576 .
Wastegate solenoid 1997157 .
Wastegate solenoid filter 801528 .
Wheel Studs (M12 x 1.5 x 76 ..longer than stock) 22551491 .
Wheel Nut TA Mesh 16" Wheels 10194314 .
Wheel Nut Cap TA Mesh 16" Wheels 10028614 .
Wheel Nut Lock Set 999057 .
Wheel Center Cap (GN) 25525651 .
Wheel Center Cap (T-Type/Turbo T) 25518704 (black centercap with tri shield design).
Window Strip - black bottom of window (RH) 20674283 .
Window Strip - black bottom of window (LH) 20674282 .
Weather Stripping, Outer window Right hand 1#20674282 .
Left hand 1#20674283 .
Weather Stripping, Door left/right 20211180/20211821 .
Windshield Washer reservoir 25506641 .
Enough part numbers for you?
