where to get 4" maf duct
1320n10
Where is the best place to get the 4" aero duct that will hold up for the inlet side of the turbo.
If you are looking for the piece that connects say a MAF and a pipe, or alike, you can simply go to almost any Kenworth/Freightliner parts depot and pick one up for about $8 usd.
HTH
Jim
Inlet hose
I have been using smooth bore Neoprene / Fiberglass high temp. hose from McMaster Carr for over 7 years. Its available in various diameters by the foot. Its rated for 32 psi @ 300 deg. F.
Catalog 107, pg 157, the 3" is PN 5499K246, only $5.90 / ft.
Yeah, but the problem with buying the hose from McMaster is you have to buy it by the 25 foot roll, or pay nearly double the cost. I did that have have about 15 feet left over. I will sell the smaller amount for $6 a foot also. An engine that does not use a MAF will need 3 feet in order to run the cone air filter behind the headlight area. As such, $18 from me.
I have a local aeroquip dealer here that sells all sorts of hoses, i bought mine 6 feet for 15 bucks, double insulated, and has that wire going through it. ALOT cheaperthan the one ATR sells and much better quality.
