which cables and spark plugs...
a set of red armstrong wires and AC delco cr42TS or autolite 23 plugs. These work great and are cheap.
Which Champion heads, iron or alum? They use different spark plugs.
If you want wires that last and work great, MSD's come in a custom fit and have never pulled off a plug boot like with Red's wires.
iron...i used the same cables Cal put on they were the easiest to find, ac delco, but I already swapped plugs once before and they are not the same ones he had originally put on. I think they were champion spark plugs. So I'm trying to find the right ones. I just bought the CR42TS spark plugs, should I use those? Also to what gap?
