Which next upgrade?
V6Turbo
3" ATR Dual Exhaust, THDP, Walbro 255-Hot Wired, 9
Which next upgrade should I do first:
Turbo or
MAF/Translator+/Extender or
Alky Kit
From what little I know, looks like your injectors and exhaust would support a bigger turbo. The alky, however, would let you crank the boost with the turbo you have. If your MAF works okay, maybe leave it alone for now.
Wonder how others think a big neck on your IC would benefit you?
Happy shopping.
Do you go to the track a lot, or do you play around on the street more?? Do you mind buying race fuel or would you rather use alky all of the time and not worry about changing fuels??
If it was me I'd go with a big turbo, since you have a Front mount the air is already pretty cool.
I'd say go with an alky kit. A bigger turbo is nice but you can only run so much on 93 octane regardless of how big the turbo is. After you max out the combo with an alky kit then I'd say look into a bigger turbo or ported heads. I also recommend a power plate with the alky kit to get the most boost possible out of the combo.
