Which would be a good pump to get that would stand up to 100% methanol???
I was running a shurflow 8030 pump that was purchased from devils own alchol injection.
This pump has EPDM/ Nylon valves and a Santoprene Diaphpram, and runs
at 150 PSI pressure
It is reccomended that only a 50/50 mixture of methonal and water be used with this pump.
I run 100% methanol and all was working good until the pump quit working and I blew my head gaskets over it.
I am thinking it was the 100% methanol that screwed the pump.
When I jumped the relay to turn the pump on manually I could
here the pump running , but it wasnt building any pressure at all
I run aftermarket engine managment and I know I need to figure out some sort of failsafe mode so that this does not happen again.
The car is mainly a street car and only gets driven once or twice a week.
So 100% methanol gets to sit in the pump at all times.
The customer service at Devils own is Lousy and I will not be dealing with them any more
There is a pump availiable from alkycontrol that is based on the shurflo 8009
pump. This pump is meant for use with a progressive controller.
Will it work without the progressive controller???
I just use my engine managment to turn it on at 10 psi and 3500 rpm and
it works very well.
Will this pump work with 100% methanol?????
What pump is everyone here using with 100% methanol????
Allen Vos
at 150 PSI pressure
it works very well.
Allen Vos
