Which roller cam for my setup??
84GN-TX
building an engine and dunno which roller cam to get. Turbo is a precision 6152e, 3k stall, 3" DP, ported irons with bigger valves. shooting for mid 10's, turbo is good for 640hp.
If you do a search you'll find a TON of info on this. Or call one of the vendors like Mike at Full Throttle or Jack Cotton. Both will take the time to listen to your combo and give you a recommendation. HTH james
I was thinking a comp roller 212-212. Put one in my brothers car with same set up as yours. Still has some low end power with a great upper power band.
