May 16, 2004 #1 V v8etr New Member Joined May 7, 2003 Messages 67 I have a buick with a 67 turbo , champ alum heads, 212 roller cam 55 lb injectors precision f/m , smc alky, and I want to know what plugs should I run? Thanks
May 16, 2004 #2 E EMcNeice Member Joined Aug 27, 2003 Messages 228 AC Delco R42TS plugs should work fine. I've been running them for years with no problems
May 16, 2004 #3 V V6 Beast Under Pressure Joined Jun 5, 2001 Messages 2,043 Originally posted by EMcNeice AC Delco R42TS plugs should work fine. I've been running them for years with no problems Click to expand... Umm.. I am pretty sure the AL. Heads take a different plug. I don't know what it is but I am pretty sure a R42TS will not work. S.
May 16, 2004 #4 N NastyGn New Member Joined Aug 21, 2002 Messages 500 For the Champion heads I use a Autolite 133 or NGK 4554. I like the NGK's better Good Luck
