now you guys aren't talking about just the front crank seal correct? i already have that...it's a neoprene rubber "circle" that goes inside the front cover hole where the crank goes in...
i'm talking about the actual gasket that the entire front cover bolts on to...to the block itself...that is rubber??? looks like the factory used some sort of flat paper gasket...so that rubber one that autozone sells for like $9 is the one to get???
