Been chasing bl# of 150 at idle...changed check valves,vacuum lines,O2,swapped MAF and no change.Put gasket paper under vacuum block and still 150,put on new vac. block gskt.
Found egr gskt leaking and replaced...now bl 144 at idle but fluctuates to 150 then back down.Tried different fuel pressure but no change.INT is now 121-133 instead of 134-145.While cruising around 2,000 rpm bl# is 127 but goes to 150 under accel.I'm confused and don't know what else to change or fix, used top engine clean and found no exhaust leak anywhere.Any ideas???
When I parked the car for the winter bl# was 119-124,only drive it approx. 1,500 miles a year.
